Old 08-20-2012, 08:41 PM
Rico Rico is offline
Max Wedge
Default weights and spring codes on a 90 ssp??
Where would I find the spring and weight codes on data plate are there any pics?
Old 08-20-2012, 09:19 PM
Are you asking what they are because the image of the door tag on your Marti report doesn't have those items? Ford didn't keep than information, that is why Marti Auto doesn't have it and doesn't print it on the door tag image on the Marti reports. If you do not have access to the original door tag, the only thing you can do is compare weights, accessory reserve loads (F and R numbers), and spring codes on door tags from similarly equipped cars.
OR are you asking how to decode those items on your original door tag?
Old 08-21-2012, 08:11 AM
You could look through the 1990 page of our VIN Project...
http://www.specialservicemustang.net/VINlist/90VIN.html
...to see what was written on other VIN door labels.
