Old 01-30-2012, 11:53 AM
Awesome Ted! I wonder if those extra holes do line up with the place you've got it bolted to keep it held down to the bumper cover. That would make sense. Does the bracket tie in where the radiator support clamps bolt on?
Old 01-30-2012, 12:07 PM
Originally Posted by texunter View Post
Yes Chris you are correct. There are holes on the radiator support that match with the angled part of the bracket. Sorry for the confusion.
Can someone remove those pics for me because they are not correct.
Ted
Took care of it. Please post up more once you get them spun around, though. Good stuff.
Old 01-30-2012, 12:51 PM
texunter's Avatar
texunter texunter is offline
Thanks Evil.
I put the front bumper back on and verified the mounting holes. The support is bent but they line up. The driver side bracket utilizes the radiator support to bumber cover bracket. The passenger side is not in the correct spot to utilize that bracket so they made their own holes.
Here you go.
1986 TX DPS M6-373
1987 TX DPS M7-XXX
Old 01-30-2012, 01:02 PM
Thanks Ted!
Also, you might send a PM to GSPI about the door jam sticker. He has a lot of super-cool detective tricks to figure out what was glued/stuck to something. I bet he has a trick for figuring out the door jamb sticker. Because it was one of those labels, there wouldn't have been adhesive where the letters and number were. So if you can use a UV light, or something like that, there should be a way to see only the adhesive there... and thus the negative for the unit number. Hopefully he chimes in here...
Old 01-30-2012, 01:06 PM
texunter's Avatar
Nice thinking!
I used it to read the buildsheet better
I have said light here in my toolbox....
1986 TX DPS M6-373
1987 TX DPS M7-XXX
Old 01-30-2012, 01:17 PM
Keep us posted! Maybe dust it with some chalk too?
Old 01-30-2012, 01:19 PM
texunter's Avatar
I can see the M6 but the rest is shiny black.
1986 TX DPS M6-373
1987 TX DPS M7-XXX
Old 01-30-2012, 01:32 PM
I wonder if you could dust it with something, or if there would be a way to "lift it" Maybe even a light pencil over paper would show something?
Old 01-30-2012, 01:49 PM
I added this one to our VIN Project
http://www.specialservicemustang.net...info231686.htm
There are two other TxDPS cars with the same DSO in the consecutive list of 10 VIN's.
Old 01-30-2012, 10:14 PM
1989 Tx DPS SSP's Avatar
Teddy, Look behind the drivers side panel to see if there might be an additional Build sheet.
Tom
