Old 06-21-2014, 10:14 AM
NHPcars.com's Avatar
NHPcars.com NHPcars.com is offline
Double Bar 7 Point Star
Awesome...Hope to see it again, in Ripon.
a bunch of other Mopars, and one Pontiac.
www.nhpcars.com
Old 06-21-2014, 11:25 AM
Solid progress, we can always use another SSP at Ripon. Keep it coming!
Old 07-24-2014, 08:36 PM
05pwrstrk's Avatar
05pwrstrk 05pwrstrk is offline
Default Progress...
Hello Everyone!!
So moving right along here. I picked up my car from the mechanic 2 days ago. WOW. Now she starts with a purpose. I had as much done to the engine without actually having it rebuilt. The reason I decided not to do a full rebuild was because the compression check produced great numbers, no oil was burning and there was just no negative signs. I did tell the mechanic to advise me if he felt something may need to be changed or if and when they did get in there it looked bad then to let me know and we'd do the full rebuild. Heres a list of things changed.
Every gasket, timing chain & cover, water pump, all bolts around the water pump and timing chain cover, serpentine belt, freeze plugs, motor mounts, radiator, clutch on the A/C pump, A/C pump changed over to new freon stuff, oil and filter(of course), oil cooler lines, Negative battery cable, a new oil pan because mine had a dent and had rust on it, and there may be other thing I'm forgetting.
There still is some road dirt and grime around the engine bay. I'll take care of that soon.
Today I pulled my speedo. No, not a tiny pair of swim shorts but the speedometer out of my car. Lol... I pulled it out because it wasn't working. When I turn the mechanism on the back the needle moves for a brief time but then there seems to be a bind which prevents the mechanism from moving. Has anyone heard of this? Is this common with Mustangs? Anyways my speedo will be off to get fixed ASAP.
1989 NHP SSP Unit# 262(?)
2005 Ford F250 Super-Duty Lariat FX4 Powerstroke 08 F350 spring conversion, MBRP turbo back w/no cat
1976 Jeep CJ7
I love my NHP SSP
Old 11-21-2014, 03:46 AM
05pwrstrk's Avatar
Default more progress....
Time has been on my side lately so I've been trying to get some more things done on my car. The heater core was original, to my knowledge, so I felt it was a strategic move to pull it prior to installing new carpet. I recently pulled the seats, carpet and dash to replace the heater core. I'm not in a rush so the project has not been to bad. I actually enjoy these tedious processes like pulling a dash in a Mustang. I did find a gremlin that will need to be fixed. Check out the pictures.
The new heater core doesn't have this nice brace like the old one does.
OLD
NEW
This disaster was found under my drivers seat. Any ideas? I've done a lot of sheet metal repair work on other vehicle bodies and I'm confident I can repair this with some 16ga sheet steel. The affected areas about the size of an iPhone. What do you guys think? Whatever I end up doing it will be better than the hack job someone else has already done.
1976 Jeep CJ7
I love my NHP SSP
Old 11-21-2014, 03:47 AM
05pwrstrk's Avatar
I left the original padding for the time being. I remember reading that other members reused some of the old padding to make their new carpet fit better.
1976 Jeep CJ7
I love my NHP SSP
Old 11-21-2014, 10:44 AM
Progress is progress. You should be able to patch that area fairly easily. 'Just another example of how hard these cars were used and abused...
Old 11-25-2014, 02:21 AM
05pwrstrk's Avatar
I picked up some great parts out of an 89 4cyl that was getting parted out close to my house. Talk about lucky! I picked up the dash, seat belts as well as some other little parts. The dash and seat belts are both in excellent condition for their age.
My old ones.
The new ones.
1976 Jeep CJ7
I love my NHP SSP
Old 11-25-2014, 02:35 AM
05pwrstrk's Avatar
Here's the dash. The dash in my car isn't too bad but this new one is just a little bit better. You can see there are little squares or rectangles patches on this dash. I assume these are from where the PO had the Velcro strips for the dash cover.
1976 Jeep CJ7
I love my NHP SSP
Old 11-29-2016, 03:41 AM
05pwrstrk's Avatar
Hey what's up everyone? I can't believe it has been two years since I've posted about my car. Wow. Time flies. In the time since I last posted a lot has happened to my car. How do I begin to get all of this adventure down here? I guess I'll just start throwing things down and see how it lays out.
2015
  • I removed the interior of my car.
  • March of 2015 my seats went for new upholstery.
  • the heater core was replaced
  • picked up my front seats sometime here in 2015
  • had my local auto paint store hand mix a blue color for my interior
  • I built a paint booth in my garage(incl. exhaust fan) and painted my interior parts
  • Dec 28, 2015 my car was taken for body work and paint
2016
  • picked up my rear seat(Nov)
  • took pictures of my cars progress at the paint shop
  • patiently waiting
1976 Jeep CJ7
I love my NHP SSP
Old 11-29-2016, 08:48 AM
Sounds great!!! But we need pictures
