Old 01-04-2012, 10:25 AM
SSPCHPSTANG3101's Avatar
SSPCHPSTANG3101 SSPCHPSTANG3101 is offline
Default 2011 Morro Bay Event
Old 01-04-2012, 10:27 PM
fallon312 fallon312 is offline
The lighting sequence for the vector light bar should go like this. The point light was a steady non rotating red. The two lights out bound from those were clear take down lights that could be steady white lights or 360 revolving. the outer two from them were one blue/ yellow insert on passenger side and one red/ yellow insert on the drivers side. The inserts had to provide yellow light to the rear to comply with the vehicle code. These could rotate or wig wag depending on which mode they were in. Hope this helps.
Old 01-05-2012, 12:15 AM
Rhino's Avatar
Rhino Rhino is offline
Interesting - A Vision bar vs. a Vector. And yes - thank you for the info, Don!
And thanks for the added pics. Wish we could see the shotgun setup/radio setup inside the car.
Ryan
Old 01-05-2012, 01:44 AM
Thanks guys! Great photos and info.
Does anyone know of any small lights that can rotate or anything that can make small lights rotate? If I'm gonna make such a large scratch built light bar I might as well try and put in rotating lights
And I might have found the "best" dash pics I will see. I also completely forgot the camaros had shotgun racks. LOL. Maybe because I hadn't seen an interior pic
I also got some pics of mounting holes off a real 92 CHP
I will post pics
Old 01-05-2012, 02:55 AM
Rhino's Avatar
Sam, are you building a vector/vision bar for another car?
You can see the rotate function when hooked up to a SS2000 unit here.
http://www.youtube.com/watch?v=me3sTmpKiGA - Around 1:15-1:45 in the video.
Although it appears the CHP didn't use the SS2000, but something in-house made that worked somewhat similarly:
http://www.wb6nvh.com/CHP2001.htm
Ryan
Old 01-08-2012, 02:38 AM
Thanks for the links!
I am actually going to build a 1/8 scale lightbar
If there was someway I could make small lights work with a 1/1 scale control head and make the lights flash like in the vid...
This may be a complicated build. lol
Old 01-08-2012, 02:27 PM
Here are the photos I found And SSPCHPSTANG3101, your pics do not show up anymore. Maybe it is just my computer?
This is the car that was restored and sold on ebay. This is when it was being stripped (note the newer colored decals, you can tell the car was repainted with it having those).
It is interesting that 2926, 2927, and 2928 still exist
Old 01-08-2012, 04:54 PM
Cool pics thanks for posting them.
Old 01-08-2012, 10:51 PM
Rhino's Avatar
OMG - Wow. THANK YOU for posting these!! Pure gold. I have, to this day, never seen the inside layout of a 92 before. Pretty sweet.
Curious - who has which #s? I believe 2926 is now in Norway (or somewhere that direction from when Matt Speith sold it).
2927 and 2928 - who has those now?
Ryan
Old 01-08-2012, 11:33 PM
You guys are all welcome
2927 - Still with CHP
2928 - I don't know. I thought you might know, Ryan. Since you almost bought the car, I thought you would know.
My dad has, IIRC, 2917 at his restoration shop. The owner has other CHP cars too (not my dad )
And I believe 2916 exists.
