Old 09-07-2012, 10:34 PM
Pushrod91's Avatar
Pushrod91 Pushrod91 is offline
Hey that's my build sheet. Lol. I signed up here today to try and give as much info to Ted as possible.
Old 09-07-2012, 10:59 PM
texunter's Avatar
texunter texunter is offline
Welcome to the forums!
If you hang around too long, you will get bit. Be careful!
Until then, I'm trying to work out the transport. Thanks for signing up.
Ted
1986 TX DPS M6-373
1987 TX DPS M7-XXX
Old 09-08-2012, 08:22 AM
I see that you are in Ramona, CA. I wish I knew somebody that far down the state who could act as a go-between for you and Ted.
Your SSP is interesting. It clearly was not ordered for the CHP to be a patrol vehicle, so I wonder what State agency used it? This car would be a good one to order a Deluxe Marti Report on to get as much dealer info and other nuggets as possible. The legal owner could also request a Registration History Report from California DMV to see who the first owner was.
Old 09-08-2012, 12:17 PM
Pushrod91's Avatar
Thanks for the welcome. As i told Ted i know very little about ssp's and i really dont have the interest in them as alot of you do. I got the car from my friend that had to get rid of it cause his sister lost her house. (He bought it from someone else) He was gonna let it go to the crusher. I couldnt see it going to the scrap yard. He had no where to keep it. So i picked it up with the intensions of turning it into a another drag car. Then my friend said he had that copy of the build sheet and said it was a SSP. I know how people love these things so i decieded to build it. Was going to with a resto build on it and turn it back into what it was. But i just dont have the time with all the other stuff im doing to do it. Thats why it went up for sale. I wanted to go to someonet that would do it justice.
I had another friend run the vin for me and he said there wasnt much history on it. So i all i have to go off of is the pic of the build sheet that you guys seen. Vins Match. This is what i got from my buddy when he ran the vin.
Originally Posted by mustangX
Not reaslly much on this vehicle. Literally bone dry. Earliest record of it was 8/2/85 when it was shipped to Ca. Then the next was 1997. Maybe since it had exempt plates?
Also, I found this small database in which has all the VIN tags for 1985 SSP mustangs
http://www.specialservicemustang.net/VINlist/85VIN.html
just press ctrl f and type in your vin on the bar below.
Old 09-08-2012, 12:46 PM
In one of the pics you posted @ CIE I saw the door tag on the driver-side door. Can you post a pic of that door tag? Thanks.
Old 09-08-2012, 12:50 PM
Pushrod91's Avatar
I also sent this to Ted. This is the only tag on the drivers door. There also is no tag behind the drivers headlight.
Old 09-08-2012, 01:19 PM
Thanks for posting the door tag. It looks like the TR code is TTTXX. Is that correct?
Date: 07/75 = July 1985 build
Exterior Paint Colors - 3V = Light Regatta blue
DSO - 720476 = San Jose district sales office, special order #0476
Body - 66B = = Mustang 2-dr sedan (coupe/notchback)
Int Trim - FBC = cloth seats, low-back buckets (F), Regatta blue interior (B), deviation "C"
A/C - Q = Bright Regatta Blue paint stripes
R - Y = radio delete
AX - E = 3.27:1 axle ratio, Traction-Lok differential
T = 4-sp automatic transmission (AOD)
TT(?) = front springs
XX(?) = rear springs
On the build sheet, the spring codes are TAA (front) and GAC (rear).
Old 09-08-2012, 01:26 PM
Pushrod91's Avatar
ttt yes. Its either xx or xy. Hard to read.
Old 09-08-2012, 01:41 PM
If the first rear spring code is X the second one is as well. The rear spring codes on the build sheet are the same (GACGAC).
Old 09-10-2012, 10:26 AM
Pushrod91's Avatar
Ted passed. If anyone in CA is interested let me know. Like to see it go to a good home.
